I need some advice on two Casio AMW-320R divers watches.  They have been living in my watch box for years and I finally decided to get them out and see if I could fix the one.  Allow me to explain.
One works perfectly, the other one the digital part works but the second hand doesn’t move.  In fact, it could be all three hands may not move, I’m not sure because I didn’t check before I started working on them this time and I don’t remember.
My plan was to take parts out of the good watch piece by price and transfer them into the one with the non-working hands to hopefully figure out which component was faulty.  Well, somewhere along the way of swapping parts, I got confused which part went to which watch and now both watches have non-working hands!  Hurray!  Progress! At least I accomplished something.  Now I really have two watches that are identical.
At one point, I had both watches completely apart and I’m sure I’ve got them back together correctly because I can see the axels (I know that’s not the correct term) of the gears through the top plate and can tell they are installed properly.  All three hands move by manipulating the stem and move around quickly when the watch is placed on a demagnetizer.  Just looking for some idea of were I should start.
My gut feeling is it’s likely to be more electrical than mechanical, as maybe I shorted something out taking the battery out with my tweezers or something?  That’s the only thing I can think of.  If anyone has any suggestions what I can check, I would appreciate it.
Thanks in advance.
Is this the first watch movement that you have taken apart? Isn't that easy to re-assembly them correctly, even for quartz modules.
If the pulse doesn't get it restarted, chances are the module id done with, that's not uncommon at all.
Maybe that's a good occasion to move on to a mechanical watch.
Hi that's a bit unfortuate having two dead ones,  Do these watches have two batteries in some of the analogue/digital have two one 1.55v for the analogue and a 3v coin cell for the digital
JDM, I’ve taken apart a few movements before but only for general cleaning in an ultrasonic cleaner an nothing in the line of diagnosing any type of faults. Also, these were just practice watches as well.  Thanks for the reply.
Watchweasol.  I’ve included a few pictures of the movement of the watch in question.  It’s marked 1374 on the back plate.
Thanks for your time.
Tom
Quite common for the coil on these to go open circuit. There are two different variations of the movement, one like the one in your pictures with two buttons on the side opposite the crown and another one with one button on either side, no electronic movement parts are interchangeable between the two. It's easy to check the coil for continuity, with a multi meter once yo lift the circuit off...You might be lucky with one watch with a duff coil and the other with a dead circuit.... The resistance of the coil, out of circuit should be around 2k ohms...
Edited by JohnD
JohnD, I think you’re right on with this one.  Both coils are open. Now I just need to see if I can find a place to source them and then see if the other electronics are okay or not.
Thanks.
Thanks.
If there  is no obvious signs of corrosion on the circuits they are probably OK. The vast majority of O/C coils are due to ham fisted battery change attempts, where the coil is nicked with a screw driver......
    • That's strange. I re-serviced a couple of watches after about 4-5 years and there looked to be no loss of oil. These are watches I very rarely wear, and I probably over-oiled a bit back then.
    • That's nice! Cousins do know how to make money in a way that benefits themselves and their customers. Repairing wouldn't be the same w/o them. For most purposes, 10ml goes a long way. However, with a few exceptions, I’ve started applying Fixodrop to all parts that come into contact with grease or oil, so I went ahead and got the 100ml bottle. I just serviced a watch that I last worked on seven years ago, and to my surprise, it was practically dry—almost no oil left. I suppose it either evaporates or migrates over time? I just now browsed the available options and noticed that Fixodrop 8981 ES/BS-10 (Ready to Use) is a bargain at just £104 per 100ml. Well, that is, compared to Fixodrop 8982 ES/BS-20 (Ready to Use), which goes for £850 per 100ml. According to ChatGPT, 8981 is intended for inexpensive watches serviced by enthusiasts, while 8982 is geared toward high-end timepieces handled by professionals. Or could it be that Moebius found a way to squeeze more money out of the same product? Hmm...
    • Often times the belief is when you're making small parts you Need a small lathe like a watchmaker's lathe to make small parts. But for gear cutting its oftentimes better to have something bigger. Then realistically you might end up with several things not just one machine for everything. Depends upon your machining skills and the equipment you have. This is where having a slightly bigger equipment allows you to make all kinds of things where if you have a tiny equipment you can not really make bigger stuff it's very awkward. Then indexing is all kinds of ways to do indexing a very popular way is with the stepping motor a worm gear like at the link below https://www.ebay.com/itm/191714031261 What's interesting with something like this is you can micro step at end up with basically a infinite quantity of indexing. But you still have to build some things. For instance here's an interesting YouTube channel and an interesting video. His watchmaker's lathe is a little bigger than what I'm typically used to for watchmakers lathe. As a rather interesting cross slide and notice he makes just about everything. Then he gets the indexing something purchased surplus but it's basically just a worm gear stepping motor his has way more hands-on control but it does the exact same thing as the one up above. Then if you read the description of the video is in a shop of creative people to build all kinds of nifty things like the stepper motor controller etc.
    • Yes they are a silly price. Fortunately the 10ml Moebius bottle has a metal gauze in the top, so no need for a separate bottle. They shouldn't be!  Mad idea. I changed them for coloured ones
    • There were colourless cap jewels on an oris 581 KIF I was looking at. I was convinced I’d lost them when I put the jewel into heptane and couldn’t find the caps. I didn’t know colourless ones were a thing!
