Hi Watchmakers,
I got a puw 60 what I cleaned and would not run because the left handed ratchet wheel screw is pushing down the ratchet wheel and locks it. As it cannot move the movement would not run. This is how I received it, originally i thought that it is just dirty so I cleaned it. (interestingly the ultrasonic bath removed the nickel/chrome -never could make the difference- plating at many places) What am I missing here? A washer? Or something else?
Best regards,
Lui
4 minutes ago, clockboy said:
Maybe the ratchet wheel is upside down.
Unfortunately not, i was thinking of that, but the ratchet wheel has a recess so the screw could center it and the wheel should be able to turn around it. Now that I see the picture it is actually upside down but it is just because i put it back for the picture and did not pay attention.
Edited by luiazazrambo
Ok most likely it is not the correct ratchet wheel . Looking at the pic and the gearing it looks like it is a touch to high.
What you have circled in the picture is the crown wheel and screw. The screw should have a shoulder section to keep it distanced, or a (lost) washer was used there.
Quote
That is why I wash with petroleum only and IPA only, by hand. And mild ammonia only if there are brass / gilted parts.
Then every other thread we read about beginners (but not only) getting fixated on on machines and commercial solutions.
Edited by jdm
Crown wheel of course.... screw has no shoulder probably the washer was then lost.
I am learning... very slowly... went to bed 4:15 this morning. I was shocked by the result after the cleaning i guess i must pay the price of the knowledge. Very painful so far and not much knowledge gained, well to my former myself i go with lightspeed but it is just not enough and they say there is no 2 x lightspeed. :D
Just took a look and PUW movements in general has a crown wheel with a small bearing. And by the looks of your ratchet screw I would say it is missing the small bearing and is upside down.
I just pop a picture on a common PUW ratchet wheel here so you can see what it might look like.
  • Thanks 2
Hi Luiz  HSL is correct the inner ring  is missing and the screw locks down on to the crown wheel not the ring. The part is numbered 422  and known as the crown wheel ring.
I definitely don't have that bearing ring, and yes it is upside down because i put it back for the picture and did not pay attention for the details. I made it difficult to help me.
Unfortunately I am out of this part for the PUW 60, but there are a couple of PUW movements using the same.
Kronradring 422 (60) , PUW 60, PUW 61, PUW 61S, PUW 63, PUW 65
If you sometime in the feature would need another bearing I have Kronradring 422 (70) for PUW 70, PUW 73, PUW 80, PUW 260, PUW 261, PUW1260, PUW 1261, PUW 560, PUW 561, PUW 562, PUW 563T, PUW 564T, PUW 565T, PUW1560, PUW 1561, PUW 1562, PUW 1563T, PUW 1564T, PUW 561E, PUW 562E. PUW 1561E, PUW 1562E ;)
 Pforzheimer Uhren-Rohwerke GmbH
So still learning, this was the first time i touched an incabloc setting, i must say it was a delight to deal with it not like those other once in the CAL 400 causing me nightmares (little ring with 3 spikes 120 degree apart from each other). I go for a double treasure hunt now, picking up clocks and doing metal detecting if the weather and other conditions allow me.
That yellow section under the balance assembly is one of the places where the coating was removed by the ultrasonic clean, luckily its my own watch. :)
adding extra info
  • 4 months later...
This movement was sitting on my desk for a long time. I finally ordered a few things from CousinsUK, a bearing included. I was so happy but not for long, I lost the cannon pinion meanwhile.... I cant find it anywhere. All of the other parts were in the container, but the cannon pinion is gone. The carpet must have it, or the hoover.
Well, search the carpet - each square centimeter. As for the Hoover - you will have to empty the bag and perform "search & rescue" to get your cannon pinion back. You will not be the first one to go through such unpleasant task... Good luck!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
