It arrived this morning and it looks better in the metal than the photo.
As Marc and I suspected, it is a cylinder escapement. I was worried that a tooth might be missing from it, as it runs for a couple of seconds and stops, but on close inspection it is perfect. A good clean and a new strap will make it good as new. At £37.85 including postage, I'm well pleased! :)
It transpired that the movement in the watch is a Fontainemelon 602 calibre with cylinder escapement. Here are a few photos, the first two were taken during the dismantling and the rest are the fruits of my labour. I replaced the mainspring and everything else was just given a good clean, lubricated then reassembled.
After cleaning and assembly.
The porcelain dial was in excellent condition with only the slightest of damage, luckily under the bezel where a knife has caught it in the past. There was also some brown staining from oil, this was easily removed with some household bleach. The crystal is original, easily identifiable by the small flat spot in the middle. I gave it the usual Autosol polish and it looks like new.
I decided to leave all the historic marks on the case, and gave it a gentle polish with a silver cloth.
I had missed this thread.
Nice job and watch! Amazing how the simplicity and combination of elements in this design make this watch so appealing. Roman numerals and fancy crown...you can't go wrong with those!
Cheers,
Bob
It was quite the thing to mark the XII in red at that time - gave it that extra "military" feel. You see them in blue occasionally.
Nice watch excellent job. Is it a trick of the light but is the X11 a different colour,if so I have never seen it before.
Perfect answer by Will. :)
Nice work,  looks like new,  well done.
Cylinder escapements must be getting a bit rare nowadays.  For high end cylinders they used to use a Ruby cylinder,  how on earth they managed to machine it is as big a mystery as the Great Pyramid.
Wow, I didn't know that Roger. It beats me how they made the steel ones never mind making them from Ruby. They are really very delicate and fiddly to work with.
That is great work there! Getting a garden office installed in the summer so should be able to so some more repairs then and have a very similar watch to work on you have inspired me to do that first
Excellent!
Take great care when removing the balance assembly, it bears no resemblance to the anchor escapement and it's very easy to cause damage to the escapement wheel.
I came across this website  http://www.watchrestoration.com/miniPP1.html  while looking for information on cylinder escapements,  he actually made a new cylinder for a very small Patek Phillipe watch,  amazing.
Picture is of a Ruby cylinder,  it's not easy to see but there is a cylindrical piece of Ruby fitted into the steel cylinder.  It's not as I imagined where the whole cylinder was made from Ruby,  they have just used it in the high wear part,  but still amazing work.
Thanks for your last post Roger, it is truly fascinating to see what some people make. That is is the kind if thing I just love reading about, there is just so much to learn. :)
Wonderful job Geo, and great pics as well.
I'm glad you left most of the marks on case ... if only some of them could talk: I bet they would have some truly amazing stories to tell.
Geo,
Great job! That is a beauty! May I ask what you used to clean the dial?
Thanks!
(I'm envious of the skill with which you and all the others clean and reassemble these specimens!) Thank you!
Because these old dials are porcelain on copper, I use neat household bleach on a cotton bud then rinse with clean water.
Do not use bleach on more modern dials with a paint finish!
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
