imageproxy.php?img=&key=8c41f123521b3122Not rare, nor exceptionally valuable, but of my several pocketwatches, it's one of the most useful and endearing.  The third hand sets the alarm. At work I might go to lunch at different times, there is no clock in the breakroom, and dealing with protected information we must lock up our cell phones before duty. Watches are how we tell time there. My alarm tells me when my break is over.
Technically assembled by Public Watch Co, with a Baumgartner 222 movement, it is surprisingly accurate for what it is (that, and I spent quite some time regulating it). I think it's around 50 mm +/-.  Value-wise, it's probably a step up from "Dollar watches", but I love it anyway; it's alarm has been a handy reminder quite often.
Very nice, very nice indeed.  There is a watchmaker on youtube who's name is Richard Perrett. If my memory serves me well, I think he did a vid of an alarm pocket watch. Worth a look.
I'd have to check, but I think it's a video that I've seen.  There are a few of these handy little watches out there.  Maybe I could post my own video here.  I'll have to film it in action!  That'd be a cool thing.
Edited by KarlvonKoln
Typo
So here is the requested video.  Isn't the alarm feature just the handiest doggone thing?   Sure, I could set an alarm in my smart phone, if it was required to lock it up, and if I didn't have to open the app, pull up the date, set the hour, then the minutes, then am or pm, then select a tone, then hit save (then look at the time on the screen and realize I now have to clock back in anyway).  Perhaps I exaggerate, and perhaps not, but this certainly seems way easier, even one-handed.
I had to trim the video down a bit, but it still seems to show enough about how simple it is to work it.
Weirdness ensued.
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
