A few days ago an elderly friend sent me his radio (Klik) watch.
I had never seen one before or indeed any radio watch. I cleaned
the battery contacts and installed a new battery-the watch ticked
but was wildly out of time. After consulting e---y bay on the problem
I still could not set the watch. In the end as it was getting late I got the
idea that my portable radio might help so I turned it on- wrapped the
watch around the aerial and left it. Sometime later in the evening
there was an audible "ding" and the watch had set itself to the
current time!! I understand that the source signal no longer comes
from Germany but the atomic clock is now in Cumbria.Hope one
of you guys will comment on this little case.
Minuteman3
Hi Mnuteman, I can only guess that the watch was searching in vain for a signal when it was running way too fast. Placing it over the aerial helped catch the signal and allowed it to set itself.
My kitchen clock works in the same way, when I change the battery, it birls and twirls, stops at twelve, then sets itself to the correct time. Regarding where the signal comes from, I have know idea.
Signal comes from Anthorn in Cumbria.
en.m.wikipedia.org/wiki/Time_from_NPL
As for the aerial trick its as Geo said.
Most people find metal shelves or racks in the kitchen work well too.
Edited by ro63rto
  • 9 years later...
I have the same KLIK watch that was my late father’s. I took it to get checked.
The watch repairer said he changed the battery but it would appear to go on but then go off. I wonder if this is the same fault as the one in your article. I have been given the watch back. The screen is blank.
Try pressing all four buttons at the same time - every segment on the screen should show for a second or two, plus it beep.
That's a "hard reset" which should get it going, if the battery is making proper contact and there is no fault.
I've just tried it with an old Klik of mine, with a new battery.
If that works, it may take anything from a few minutes to a few hours to lock on to the time signal and set itself. Keep it away from computers & wifi devices etc. to minimise interference until it sets.
Edit - mine set itself while I was typing that! Not bad seeing it's not been used for years.
Edited by rjenkinsgb
