More seiko im afraid, i have no knowledge of seikos but once again it looks like a cool chrono so seeing if its worth the punt or be cheaper to buy it working ! So impressed with the help I thought I'd go again
Thanks in advance
Agree with Geo, unless you can obtain another dial and glass as the movement looks sound.
The pushers get stuck like that, usually, because the o-rings go hard and brittle. Be careful when you take out the movement ring though as the pusher springs can potentially fly away and go missing :)
I love these Seiko chrono's -
I agree with the previous posts if you could get replacement dial & hands it would be a great watch. What Seiko,s I have worked on they are easy ish to work on and run great.  Might be worth adding it to your wish list on eBay so you don,t miss one when one is listed.
This what it should look like which is a great looking watch
Edited by clockboy
Hi Jnash,
Looks to me that watch sufferred a crystal damage and a lot of carnage to the dial and hands, possibly center pinion and wheel..not too clear.
Movement looks clean.. It is common to find the auto weight bearing worn resulting in damage to the autowind plate but yours seems good.
I would imagine this watch suffered the damage when it was fairly new and got put away so you may have a good movement (see remark on the center pinion/wheels)....but...... I cant figure out the little holes in the dial.. it could be someone was already in there and you may have a mongrel.
I would proceed to tear the movement down, inspect as you go and if its all good then source the parts needed to fix it up
Anil
all sounds correct to me, holes in the dial are for a sub bezel.  i can imagine along with the hands and dial i would need a seconds, cannon aswell as its locked up.
May keep it for a rainy day..
Thanks
One of the all time classics and better than money in the bank.
all depends if im going to spend more than what its worth.. which im still unsure of, ive been really surprised with seikos for what they have gone for!
Hi Jonathan. If you do decide to refurbish the watch, have a look on the is site. I have bought a few bits from Stephen before, his prices are reasonable and his service is excellent. :)
based on the case model , this is how it should look , quite nice actually (pic stolen from the site in the watermark)
not the inne bezel (showing markers) layer on the dial
Edited by jnash
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
