First attempt at an English Westminster chime movement
Beagle2
Hello,
Well, several months on and I’ve finally put it back together.
1/4 chime seems to trigger each quarter, and it runs for 8 days + so the new wheel must be perfect....
however, it’s like 2 hammers are excluded from the chime, i.e it’s it ‘strike mode’ all the time.
On the hour the bar lifting the 2 hammers moves down and you get the chime with all 4 notes and then the strike. But each quarter after it’s just 2 notes.
Otherwise it seems ok, although it doesn’t seem to strike at 12 for an unknown reason.
Hopefully the pic and video show what I mean.
It’s like the strike is going into warning at the wrong moment (?)
Any ideas would be greatly welcome.
Edited by Beagle2
Things are not set in there proper place, because two hammers are at the lifting position. This might work it could depend on other things, but its worth a go.  Undo that screw that the red arrow is pointing at, you can remove it. With your fingers move the wheel that lifts the hammers around so the hammers lift and go go down in line, this is for the quarter past or the last of the three quarter . When you are OK with this put the wheel back on an tighten, and take the hands around watching to see if all is right, if a hammer starts to lift on the warning adjust that wheel a little by one tooth. Some times this will fix it sometimes not so lucky, depends how far out things are. Here is the scale for your Westminster chime so you can follow this if you are not sure how the sequence works.
Note the Quarter is the same as the last on the three quarter
Hello,
Sorry for the late reply, and thank you for the pointers.
Instead of adjusting the wheel by one tooth I was able to bend the pin slightly that locates in the 'star wheel' which actions the strike.
Before it was stopping on a point rather than a trough, missing the last chime. This explains why it wouldn't strike 12 (i.e. you only got 11)
I was also able to align the notes with OH's sheet music - thanks
However I'm still not happy with it.... I've run it for about a week and sometimes (~1/15) times it misses a chime or chimes the wrong length...
I'm pretty sure it's the 'long lever' failing to drop sometimes. I think it's catching on something where it contacts the front plate.
Having got this far I'm going to strip it again and polish the contact points of this lever. Also all this tinkering has allowed the odd bit of fluff etc to find its way into the mechanism.
If that's the case I think you need to check all the wheels on the strike and chime side to make sure they are all in line. Then you start adding the strike and chime works, making sure each part works as it should. Just ask if you are not sure. I can take a bit of practice with a chime, understanding how it all works is the ticket.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
