Hello!
I recently purchased the very useless Bergeon cannon pinion removal tool! yay. I was unaware at how pointless it is at the time of purchase
I decided to take it apart and the parts flew everywhere and now I'm struggling to reassemble it correctly. I think I may have lost a part or I'm missing something when putting it together because it doesn't work.
Could someone shed some light on this for me please :)
You're welcomed. I bought an equally useless vintage one.  Some of our members suggest putting a sheet of plastic or foil over the cannon pinion to get a better grip. I've not tried it.
I'm actually in the process of shaving down the sides of the collet so that the jaws can close down further. I'll post an update if it works. If not I'll be machining a new collet from scratch.
This is the reason I tried to dismantle it, I'm hoping to file it down.
Any chance you could give me the diameter of the ball bearing?..I've scoured the workshop and it's long gone.
Have you tried filing the jaws yet?
I got mine to be able to grip a 0.9mm wire. I could probably get it down to 0.8mm.
If you look at the photo of my puller, it has an extra pin and spring. I think it would work even without this extra pin.
Have you tried filing the jaws yet? I got mine to be able to grip a 0.9mm wire. I could probably get it down to 0.8mm.
I don't have a file thin enough to get in there unfortunately [emoji17]
Sent from my SM-G973F using Tapatalk
Just now, ThrobinsonCrusoe said:
You can do things like that sliding emery cloth or or emery paper over the blade of a feeler gauge.
Thanks for the tip, this worked perfectly! I just slid some emery cloth between the teeth and now it works on much smaller cannon pinions.
You're very welcome and to provide feedback consider using the like or thanks button, or the upvote and resolved mark in the watch repair section only.
I wonder if Bergeon was afraid of jaws breaking and made everything thicker at the expense of grip size? The collet in the first pic is quite different from Hector's above, and here you can see mine; the slits are quite big, and the jaws are shaped down to a sort of point. I have two and both will grip a 0.5mm screwdriver blade very well, both are at least 40 years old and neither are broken. Someone could make replacement collets and make a bit of cash maybe selling to those who can only find the crappy Bergeon version!
The new collet is actually very fragile, your old one looks much more robust. Mine actually cracked whilst I was filing it as it's wafer thin at the top, and the whole thing distorts very easily.
I think Bergeon are just producing a cheaper tool now but still charging a premium.
I have just purchased a new cannon pinion tool from Cousins. Tried using it on a ladies pocket watch movement and again same as you guys its too big. I will need to get a collet with a smaller hole or grind down the slots so it will close about the cannon pinion. At £59 it an expensive tool that is not much use as it is.
Is there a smaller collet that is available. I seem to remember Mark having this trouble in a previous post and I cannot remember his solution.
I filed down the gaps between the collet teeth with emery cloth. You have to be careful though at it's quite fragile.
I would have returned it if I hadn't lost the ball baring, so be careful when taking it apart.
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
