Hey
Trying to open the 2 barrels that hold mainsprings in this cal.
you  can crack em open a little but they then seem to be attached to the arbour at each end.
Is there a knack before i use force on them.
cheers
gary
The "knack" is to be patient and use the proper technique. You can press the arbor down in the barrel to lift the lid a bit and then use hands levers.
Seems like a plan.
Cheers
Gary.
Hey
Finally got them apart 1 came off easy and is the usual construction barrel lid and base and arbour.But the other 1 has the arbour built into the lid,.going to be fun getting the mainspring attached.
we live and learn
cheers
gary
Would you post a good picture? Normally the arbor turns in the lid for winding, beside being made of a different material.
