Pallet jewel - shellac
I wanted to test the travel between the banking and the guard pin and managed to loosen the exit pallet jewel in the process of doing so. No harm done, it's NH36 I bought for testing. The exit jewel is under the pallet bridge, very much impossible to test it. I couldn't get there with an oiler so I used a curved dental too. I wasn't applying much pressure, at least I don't think so but considering the scale, the dental tool is quite large. After all this, I didn't manage to test the travel on the exit jewel, entry was fine and accessible.
Couple of questions:
Was it my fault or was the jewel not secured properly? I thought you'd have to heat the shellac to loosen it or apply a lot of pressure to remove it. Not that you'd want to do it with pressure without heating it first, I'm just trying to work out why it happened. This is a new movement btw.
Do I need to remove the old shellac and apply new? It is as secure as it can be with a loose jewel, it runs well when I assemble it and put it on the timegrapher. The jewel doesn't move back and forth, it pivots down if I apply medium pressure. I'd be tempted to heat it and add more shellac. I'm sure the correct procedure would be to remove the shellac from the jewel and the fork and apply new but it is in perfect position so I'd rather just heat it and add little more shellac.
In theory adding a tiny bit of shellac to a pallet jewel seems like a straight forward task, largely that (on it's own with no precise adjustment required) is pretty simple. Despite that, it does take a bit of practice - drawing the shellac into a fine point of suitable thickness so it doesn't just melt and float about in heat current above a traditional tool for the purpose.. and adding more might not be necessary.
You could try reheating the pallet on a brass plate, so that the shellac reflows.. you can try sticking a bit of shellac on the plate to know when it should be warm enough to melt.
OK, so it is not necessary to remove the shellac. I'll try reheating it first and see whether it's going to set. If not, I could perhaps try a very small flake/shaving on the top and heat it until it starts melting.
It sounds straight forward, but considering the size of the pallet jewel, I know it's going to be a nightmare at first.
I'm going to have to make the jig first of all. I'll have to look for a thick piece of brass or copper, 1/4 inch ideally. According to the book I have here it is better as it retains heat longer hence doesn't have to be reheated as often. Cousins only sell 3mm sheets though.
Go on ebay and by a vintage pallet warmer/ jewel setter. They make the job a 1000 times easier. A combination tool is also good to use and they are more common than the jewel setting warmers. Like my grandfather use to say “they just dont make them like they use too” i believe that also applies to watchmaker tools.
But in some cases one can make his own, below our Host Mark Lovic demonstrates
Reflowing the shellac should work, but if you want to add some it's good to make a "shellac applicator"; heat a corner of shellac above your flame until it just goes liquid, then stick a toothpick in and pull away. You'll have a long strand, break this off a few mm away from the end of the toothpick and you can now apply it where and how you want.
  • Thanks 2
That's really good. Far better than the flake/shaving I was thinking of.
I'll see what is on Ebay. To speed it up, I'll probably end up making one from the 3mm piece if I can't find anything there for a reasonable price.
If I find a thick piece of brass/copper I'd like to make one as per the picture bellow.
The 'slot' and the hole are there to stop transferring heat from one side to another leaving the other side cool.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
