So a friend asked me to change the battery on his wife's Cartier Tank Quartz. It has a Cartier/Ebel 81 movement which I believe to be equivalent to the Frederic Piguet 8.20  calibre. As it turns out the watch was subjected to moisture in the past and the battery was also corroded :(. A new battery didn't fix the issue - so I decided to clean it. Upon disassembly one of the battery strap screws was corroded into place - it took some creativity to wrestle it out. But now, careful inspection seems to indicate that the 2 strap screw posts are actually fit in place with what looks to be either a black plastic or rubber washer or similar fitting - presumably as an insulator. I cannot clean the main plate in the ultrasonic with these plastic/rubber seals in place. Can someone please confirm that this is indeed what I am seeing and offer any advice on whether I can safely remove these fittings (and how). I am reluctant to just start pressing them!
This image shows the "stuck" strap screw. Notice the corrosion around the battery area and near the removed strap screw hole as well.
Finally got the screw out!
You can see the black inserts below.
Here's a view from the dial side:
I suppose I "may" be able to clean this plate in my standard jewelry ultrasonic with just hot soapy water instead of my watch cleaner. Thoughts??
I'd be concerned about the EB, moisture ruins it or the circuitry pulls excess current which runs the battery down in couple of months.
Regards
Regards
EB??
8 hours ago, JohnR725 said:
I am attaching the technical brochure which has some information on cleaning.
This is very helpful - has a bit more detail than the other docs I have. So - we now have this movement being equivalent to the Cartier 81, Ebel 81, Frederic Piguet 8.20 and the Piaget 820P :).
I am still very surprised by the cleaning instructions in the Piaget document. They explicitly state that you can clean the main plate conventionally. But I am certain that there is an insulator between the battery strap screw tubes and the main plate. I cannot imagine they would not be substantially damaged by watch cleaning solutions. This movement requires the + side of the battery to be placed down and make direct contact to the main plate. So the strap is negatively charged and must be insulated from the main plate. I am curious if anyone here has actually cleaned one of these in a cleaning machine. I am heavily leaning towards my prev thought which was to clean the main plate in my water-based jewelry ultrasonic instead of the Watchmaster.
Edited by sstakoff
  • 3 years later...
Can you tell us how this went?  I now have one on my bench.  I've printed off Tech Pub.  What did you find or learn while servicing yours?
V/R
Tim Psaledakis
North Conway NH
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
