Hello again,
I recently cleaned and oiled an ETA 2834. After this I started regualting the watch. I've been at ut for hours and the best I can get is 3.3ms. The timegrapger does show 2 staight lines some of the time, but ofter it's all over the place. It not magnetic and the spring looks to be in good condition. Does anyone know how to fix this? Also amplitude is either 320 or 170 degrees on the timegrapher.
Thank you.
It's likely 170° all the time, but being so low is confusing the Chinese algorithm.
Sometime is touching or loose, likely in the balance / escapemente area, but it could be elsewhere too. Time to apply the usual stepped / excluding diagnostic.
Edited by jdm
Hi  I would seek another method of checking the watch,  or checking the timegrapher with another watch to confirm jdm's suspicions.  If the Known watch performs ok on the timegrapher with the expected result then the watch is at fault, Which then confirms the suspicion.
as a reminder if the timing machine has dots all over the place then the numbers mean nothing. When Chinese machines work they work really well when they don't work they like to give you numbers I guess to make you feel good but if you can't see you something that resembles the waveform of lines the numbers are worthless.
ETA 2834
then is this a clone or a real eta? Also does it have a – number after it and what kind a regulation system does it have like perhaps etachron?
Sorry, I meant 2834-2. It's a real ETA from a 90s Mido. Im not familiar with regulation systemts, but it's the same as all other 28xx movement I've owned.
I suspected that I had used too much oil and I cleaned the Pallets. After installing it the beaterror went to 1.5ms, amplitude to 150 and the timegrapher draws a consistant line that matches with the numbers.
I am not an expert, but it looks like the balance swings with more amplitude than 150. Could it be wrong? I havent changed the lift angle.
The machine is very unlikely to get the amplitude wrong. Of course you can test it with another watch. If this is the first or one of the first watches that you reassemble don't be put off, unfortunately is not that easy to get everything right.
I've been tinkering with watches for about year or so. I have cleaned and oiled several watches with good results. Sometimes I mess up the oiling, though and I believe that might be a part of the problem since it got signifigantly better after removing some. Maybe the oil is stealing the power from the spring and weakens the amplitude? I think I'll redo the watch.
7 minutes ago, Bopmd said:
.Maybe the oil is stealing the power from the spring and weakens the amplitude?
I don't think so.
It would be good if you at least try to identify the problem instead of going by rote.
Listen to the actual sound
Closely examine balance and escapement
Check pallet fork springiness from one side to the other
Check train sprinning freedom
These are just some checks, more would be descrine in so many of the postings here and in watchmaking books.
On 7/18/2020 at 11:36 PM, jdm said:
I don't think so.
Ok, thanks. The ticking sounds off. I'll look into it.
Hi  I am not familiar with the timegrapher but most of these type of machines have an audio out put, If yours has then listen to the amplified ticks and determine wether the beat is ok    ie  tick...tock  and not  tick.......tock.
As explained many times, the audio output on from the Chinese timegraphers is not the actual one, but a digital syntheses useful for nothing.
13 minutes ago, watchweasol said:
Hi not much good then.
Indeed. it should be possible to reroute the mike input to the speaker, if some electronically able member could help?
Edited by jdm
I would Imagine it would be possible to build a splitter which takes in the mich input,  amplifies it and two outputs one to the Timegrapher and one to an external speaker enabling simultaneous audio and visual indications .   It could have a switch to disable the Audio output and a potentiometer to control volume.       Food for thought.Needs thinking about.
Machine has the switch but is in software so would need an addtional gate to control the output based on the presence of signal. I would be happy with a fixed, reasonable volume and no external parts.
usually on timing machines at least of the modern ones witschi most of the time does have the ability to turn on the audio output. unfortunately day do not put this feature on every single one other timing machines which is irritating.
this is another one of those unfinished projects I have. As the microphone already has a preamp timing machine has some amplification there should be possible to tap into the internal circuitry and put a small speaker amplifier with volume control making use of the power in the box.
