When I was looking at bezel removing tools before I came across one made by Omega that had good reviews but it was over £1000 and you had to have a Swatch account to buy it so that was not happening. Recently I noticed the Bergeon 7152 had good reviews but a set with 6 bezel removers is £840.
I just stumbled across this Chinese bezel remover set which looks like both of them which is £130. I've studied the photos and it has got a lip for catching under the bezel. I'm normally wary of the Chinese tools but and at £130 I'm willing to give it a go. I'd just like a second opinion if anyone can offer their thoughts. The link to it is-
www.wish.com/product/watch-bezel-ring-with-elastic-rubber-watch-bezel-ring-remove-tool-5d84798e05053e0e5f20d178?hide_login_modal=true&share=web
Thanks for the reply. I've not heard good things about the type from Esslinger and I've been told the handle makes a big difference.
Apparently the Aliexpress tool is for fixed bezels as rotating bezels have more play in them and the tool can dig into the case before the Bezel comes off.
That's why I was so intrigued when I saw this tool because similar ones have good reviews.
Personally I would not get this tool unless demonstrated that it works. Check if there isn't another way to remove the bezel, for example current Seiko fixed bezel have a small lips that can be used to press on the inside. Or even better if you can do what you need to do without removing the bezel at all.
    • I put the original broken glass (whats left of it) behind the acrylic. This is how it originally looked like. A cheap clock but I like it. Very noisy when the alarm comes wake up guaranteed! 🙂
    • Update!  I've dismantled it, cleaned all the glue off, and rebuilt and lubricated the base movement. I'll leave the chrono part for another day. It's running well - great amplitude and keeping time, but it's got a beat error of 4.8ms.    How important is it to correct this? I'm worried that the potential for making things worse having to take the hairspring off and on repeatedly to adjust this. Would anyone here accept it at that?
