Whilst waiting for some seiko parts i ll start on this whilst I have the time, some vintage watches still catch my eye , this ones a auto using the AS 1906/automatic movement . the stem doesn't have the springyness it should have when pulling out the stem so probably something snapped or dislodged in the keyless works... Let's hope no parts needed as I want to finish something today!
Thank, seems I was right, but its fine lucky for me my parts site came into play and I had a spare... Or two
Lucky break! jnash you will finish something today! I'm in the same mood with a kinetic...I'll try and post pics if successful.
Yep this one just got finished, looks good, always nice to start the week off with a new watch ..
I'll upload some pics if the finished item in a sec
Full write up on my site when I get a sec however some pic's
Edited by jnash
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
