I have my Seiko 5T52A completely stripped down to the main plate and I'm ready to clean and oil.  I have 6 plastic wheels and the main plate is plastic as well.  Question, will it hurt these plastic parts to submerge them in lighter fluid or should I use air to clean them?  Second question, none of the plastic wheel axle holes call for oil, should I oil them anyway?  Can it hurt them?  I think not but I thought I would check with you guys.
Please find attached PDF which includes stripping procedure + lube chart.
I am not sure of the equivalents for the oils but I think S6 is D5. Others might have these
Seiko 5T52A.pdf
Edited by clockboy
I never oil the pivots of quartz watches, for the same reason I don't oil the pallet pivots on mechanical watches. Never had a problem with this over the years. However, you cannot use any kind of harsh chemical on the plastic plates - you will find that the surface may go soft and in some cases may even melt.
This is where a cheap ultrasonic machine will come in handy. Highly diluted soapy warm (not hot) water and about 15 minutes should do the trick and I should point out to dry immediately with tissue and make sure it is completely dry before re-assembly. If the wheels are plastic then cleaning them with Rodico is the safest way in my opinion.
The above tricks are my own method and would possibly be frowned upon by purists. :)
    • Hi folks, I'm doing some homework on getting a watchmaker's lathe, and it's clear I have a lot to learn. But I know one goal: I want to be able to fabricate wheels, which would require an indexing capability. I know how to use large lathes- like, giant metal lathes- but my experience is a few decades old now (but you never forget the smell of the metal cutting oil). So I'm looking to learn anew, and have a goal to get to a point where I can fabricate some basic watch parts. I also have no specific timeframe and want to do this right, so I'll be patient and learn what I need to before spending the money. I know I'm not going to get anything for a pittance, but I'm also not really able to put together the scratch for a $5-$10k lathe. What's out there for a hobbyist that can either handle some fabrication out of the box or can be relatively easily made to do so? Thanks!
    • Hello and welcome to the WRT forum.   This usually points to broken balance pivot.  Though a watch in need of clean & lube can do the same. Easiest diag would be to  see if balance pivot doesn't stay in hole jewel of the setting, when you lift one side of balance rim with an oiler or gently with pair of tweezers. Another would be to detach balance complete from the cock and take a look at pivot under high maginfication.  Regs
    • Ahhh, yes.  I hadn’t thought of that.  I’ve serviced quite a few of these and the first time I didn’t realise it was a ships strike pattern!  Ha ha, confused me totally until I realised.
    • Hi Mike, I did, thanks. Found this clip that was really helpful:   It says Seth Thomas but it's actually the same Hermle I've been working on. I'd had it working correctly all along but hadn't noticed that the lever with the sprung end stops the hammer a bit short of the bell on the second ding at the end of the half-past sequence. If only I'd put the bell on when testing, rather than just looking at the hammer, my ears would have told me it was working,  even if my eyes didn't!
