Hello dear watchfriends,
I have a questing. I have here two watches of a friend. Both vintage with a FHF standart 96 movement. A far a I know the FHF 96 has 18.000 bph. When I put the movements on my timegrapher it says 18.000 bph by the first watch and 21.600 by the second. Who can explain this phenomenon? By the way, both watches seem to run well.
Edited by Gaus
Okay, I was not aware of that fact. I have already seen a lot of FHF st96 movement, but this is the first one that has a bph of 21600. Thank you Nickelsilver. Learned something again. Have a nice weekend. Greetings, Hans
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
