I broke the round glass wrist watch crystal on my Benrus calendar watch trying to snap the case shut by hand. Yes I know stupid on my part but things happen. I'll purchase a case closer next.
What i'm trying to find a replacement glass crystal for it
The case opening measures 1.088" (27.63mm) and the old glass crystal's o.d. is 1.090 (27.68mm) as far as I can tell. I think best go with a 27.6mm  at this point. The old crystal has a dome height of .153 (3.88mm) and the base has a inward taper that looks to be around 30 degrees where it fits the bezel. Are the 23-1/2 glass crystals you find of a similar height to what I've listed?? The replacement crystal I purchased for my Elgin streamline (12S) looks to be of similar construction and shape is the reason I ask.
Thanks for any help,
Dale
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
