2 hours ago, EatPeach said:
Hey. Just wanna know if there's a video tutorial about how to disassemble and assemble balance cock? What kind of tools do I need? Thank you!
For what movement exactly? There are considerable differences between fixed and moveable stud arm, shock springs or not, etachron or not, plus if basic or sophisticated regulator.
Unless you mean remove and refit? Any service video shows that.
Edited by jdm
a normal incabloc balance cock. I need to refit the regulator and index pin
These are friction fit, use at least a stacking set.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
