Hello, is there a short list of parts that are (or are not) compatible between the NH35 and 7S26 series?
My understanding is that the NH35A is an evolution of the 7S26, but adds hacking and hand winding.
I understand that the 7S26 came out in 1996 and was replaced by the NH series in 2011.
Thanks for any guidance you can provide.
I keep a list of 7S26 parts at https://docs.google.com/spreadsheets/d/e/2PACX-1vRN2UULQKTfKmhRStZhDdIOIQrqd6sPB-g6x2SKyQQjOvTBjG_7TQXQhAT4f1WqAX5QAPkIimi-3jqd/pubhtml
Then compare to a  NH36 or 4R36 service sheets which is posted here practically every day.
Quote
NH series are the version for OEM that says SII instead of Seiko on the rotor. The NH26 is not sold anymore because no OEM would buy it, but Seiko still makes and sells7S26 watches, because they need some sort of differentiator between mechanical entry level "Seiko 5" and one step above it, 4R36 watches of various denominations.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
