Antique car clock.
KarlvonKoln
Nothing very fancy, but something I thought was interesting, being also fascinated with antique automobiles.  A while back, I was privileged to work on a friend's Westclox car clock that he'd kept from his father-in-law's 1927 or '28 Ford Model A.  It was an optional accessory designed to be mounted wherever in the car that the purchaser desired.  You drill the holes yourself.  It runs for maybe 12 hours tops, so you need to wind it before you go.  The movement is a pretty basic pin lever and going barrel.
When I opened it to clean it, I was hit with the unmistakable smell of vintage Lucky Strikes.  My friend confirmed that his father-in-law had indeed been quite the smoker.  He himself did not partake.  As long as I live I will always know the smell of Luckys.  My grandfather chain-smoked them until he died of emphysema at 63.  This poor little clock had the yellowish-brown grime of ages of smoke all throughout the movement.  So much cleaning.  Black tar in little corners and crevices. I also wore gloves and mask because the dial had radium. Gad, and the smell dredged up old memories of my grandfather, who also once owned a Model A.  No idea if it had such a clock.  He was a good man, and a good photographer.  Tobacco addiction was less than kind to him.
The clock, though, pulled through clean and largely unharmed.  It runs strong.  The smell is gone, but some memories remain, good ones that I'd almost forgotten, in my effort to forget how my grandpa's house always reeked of Luckys.
1 hour ago, oldhippy said:
Not sure of the size of that movement. It looks very similar to the old 30 hour Smiths & Ingersoll pocket watches.
It's a little bigger.  About 65 to 70 mm if I remembered right.  It's built like a downsized travel clock.  And it's more accurate than I'd have figured.  Since most folks would only wind and set it before going on a trip, you probably won't notice a difference of about 30 sec. to a min. per day depending on temperature and road conditions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
