second hand is off th watch , I need to remove the stem, haven't worked with a lot of automatic ones . This is a Benrus 25 Jewel Fe 255 Movement, anyone has any idea of how to remove the  stem. Pic is attached here
I think it is by unscrewing the screw on the top of stem but need confirmation to avoid messing up the movement
That's a very confusing model number.
FE 255 suggests that it's made by France Ebauche and that it's a Cal.255 (if there is such a thing). However it isn't, which could cause you issues if you need to get parts for it. It is in fact an ETA movement, I think 23xx family. You may find a number on the main plate underneath the balance wheel that would identify it exactly.
As @Nucejoe says, it's the screw closest to the stem.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
