Hey all,
I have an EB 1199 where the regulator boot is fouling the balance wheel in dial up position.  The balance pivots look good, certainly the end shake isn't excessive.
Note, this picture is in dial down position but circled in red is where it fouls.
I noticed during disassembly (how could you miss) that a previous watchmaker had shimmed the cock at some point.  I don't see how this would help?
Any ideas?  Was the shim there to tilt the cock so that the regulator boot would be further away?  That sounds nasty.  This was a total non runner when I started.
Are you sure the right regulator arm in fitted on the cock?  Doesn't look bent down.
Perhaps the wheel was restaffed with a shorter staff.
I am affraid previous watch destroyer chose the easy solution.
I would check that the staff is the correct one. Have you checked the jewels, is the balance cock level when screwed down, make sure it isn't lifting up.
Hi all the previous advice is sound, either the balance complete was changed of it had been re staffed at some point, Usually the balance cock is shimmed to increase the endshake. As old Hippy remarked check the balance cock is seated and parallel to the plate and the balance wheel rim is running flat.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
