Coil Problem.
An industrial break cleaner , like Holts does a good job of rinsing off paraffin -
By rjenkinsgb · Posted
Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php -
I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
