Smiths Sandiville Mantel Clock
HectorLooi
Just received my Smiths Sandiville mantel clock a couple of days ago.
Quite good condition generally but not running. The Westminster chime is all messed up also. This will probably keep me busy for a few weeks.
There is another clock that just came up on ebay. It's for a good cause too. Proceeds go to East Anglia's Children Hospices. Really tempted to get this also. Unless one of you guys outbid me. :thumbsu:
https://www.ebay.com.sg/itm/Art-Deco-Mantel-Clock-Smiths-With-Chimes/402360864848?hash=item5dae939050:g:-wsAAOSwAHlfNAfW
I got the clock stripped down to the 3 gear trains. Tomorrow I'll separate the plates and remove all the wheels.
What would be a good cleaning solution for clocks? I've used dishwashing liquid and turpentine before. Ended up removing a lot of lacquer from the brass.
If I decide to polish and re-lacquer the plates, how do I go about doing that?
Hi Hector  depending on how dirty the movement is   I usually give it a good scrub down with either Petrol  or white spirit and oil.  The old way of polishing the plates was with a brush charged from a chalk block (still available)  when dried and pegged out.     all bearings/pivots checked . Reassemble and lubricate with Windles clock oil  its the best .     all the best.
Yes I have a Webster.
But while adjusting the retainer ring, disaster struck. The end of the mainspring slipped off the barrel hook and slipped into the ring. Now I don't know how I'm going to get the mainspring out without the end of the spring sticking out. :phew:20200821_222715.thumb.jpg.25ff7b131188f0811ef8e2d8b0eeaef9.jpg
Yup. All there. Thanks.
I've cleaned everything and am ready to reassemble. I noticed that on the chime train, there are 2 wheels with a pin sticking out. Do I need to align or synchronize these in any way?
Do clocks have tech sheets like watches, like the ones watchweasol always supplies so generously?
Make sure this wheel is about in this place, the same on the strike side, you will probably need to  make adjustments when all the wheels are fitted. On the strike side the hammer lifting lever needs to be away from the star wheel, that is the one that lifts the hammers.
I managed to get the going train running again last night. It was still going this morning despite the broken suspension spring.
I will work on the chime and strike tonight.
I now find clocks so much more interesting than watches. There are so many different types. They are less strain on the eyes, no need to get on your hands and knees with a magnet in one hand and a flashlight in the other. No need to wait for a "shake free" day to work on delicate things like hairspring adjustments or pallet jewel replacement. But they are a whole lot more dangerous to work on.
I guess the WRT community will be polarized on opinion. :D
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
