Smiths Sandiville Mantel Clock
HectorLooi
Hi Hector  I too are foremost a clock man, enjoy the variety of movements and types and as you have noticed they take a bit more care and attention  if you are to retain all fingers injury free,  See if you can get a cuckoo clock  they are fun, they have musical boxex and carousels and cone in a variety of styles you could fill the house.
  Old Hippy you were a very lucky man having spent your life time working with clocks like these,  Judging by the look of the movement there was a lot of hand made parts. They were truly a work of art and engineering and well worth preserving for the future in this throw away era we live in.  The amount of pleasure in restoring one of these clocks to good health, one can only imagine.
3 hours ago, oldhippy said:
When you get something like this in your workshop, you will know working on clocks makes it all worth while. I loved these types of movements and Longcase clocks.
Hi OH,
A million years from now, folks will study this dinasour-caliber and wonder if it ate its own kind.:o
Hi OH, some already are munseum piece.
This a present from Queen victoria to the palace of the king in Tehran,  was considered to do much better if the public saw what britts built back in those days, so was installed in a bussy square for all to see, received regulare service and was working until just recently when taken down for a major overhaul, thereupon will be put on exhibition in museum I have heard.
I got my clock all assembled and synced correctly. But when I  put the movement back into the casing, the chime and strike doesn't work properly. It's like the post of another member who says his clock only chimes 3/4 of an hour.
I studied the movement for the past 2 days and came to these conclusions:-
1) The silent lever has something to do with the problem. If I move the lever to "silent" then back up to "chime", the clock starts chiming again for another 3/4 hour.
2) The 2nd detent which engages during auto-correct position is not being lifted high enough by the long spoke of the cannon pinion wheel.
I have to decide how to ensure proper release of the 2nd detent when it engages the locking pin.
Looks like it's going to be another sleepless night. :wacko:
I managed to get the clock working and chiming away happily for over a week. I received another Smiths mantel clock on Thursday. I have it stripped down and ready for cleaning already.
I noticed that after soaking in white spirit, the brass looks dull. I have been experimenting with soaking it in a dilute citric acid solution for 15 minutes after the white spirit soak. This brightens the brass significantly. Does citric acid damage clock parts?
I have used it sparingly on badly stained brass it will remove black spots from brass that Ammonia cleaners wont but you should generally avoid its use it can react with the copper in the brass and produce patchy pink stains on the surface so its not suitable as a general brass cleaner. It is very good at removing rust when parts are soaked in a weak solution.
As wls1971 says I would avoid using citric acid in clocks.
Get a scap bit of brass and drop it in some citric acid and leave it in there for 20 minutes and come back and it will be copper colour which then takes significant polishing to remove, it is essentially dezincing the brass, or causing dezincification which is damaging the brass.
I used to restore toy and model steam engines and dezincification was our worst enemy, now don't get me started on the differences between using distilled water and de-ionised water in brass boilers as that is an even hotter topic for toy steam engine collectors than whether to sharpen your screwdrivers with hollow ground or flat edges is to watchmakers. :Laugh:
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
