Hi
I usually tinker with mechanical watches but a friend has given me his Citizen Edifice (Myota FS60 movement with AG1 cell) to look at for him. The battery when replaced will only last 2 weeks or so. Any suggestions on what it could be or am I better just putting in a new movement?
19 minutes ago, watchweasol said:
Hi I would not reccomend AG cells  some are ok but not all
Be aware, AG is not a brand just an old  denomination standard for Alkaline (1.5V) button batteries, as such these are never apt for watches (except some large Chinese quartz modules). For a quartz watch one should use SR (Silver Oxide) batteries with a 1.55V and longer lasting.
Since AG sizes are the same as some watch batteries, and they cost marginally less, sometime these are incorrectly fitted "in lieu".
Below a shameless copy from the internet of AG sizes:
AG SERIES AND CORRESPONDING MODEL NUMBERS FOR EACH AG#
AG0 Button Batteries: 379, LR521, LR63, 618, GP379
AG1 Button Batteries: 364, LR621, LR60, D364, LR620, 280-34
AG2 Button Batteries: 396, 397, LR59, LR726, 612, 196, D396, D397
AG3 Button Batteries: 384, 392, 192, LR41, LR736, L736, GP192, V36A
AG4 Button Batteries: 376, 377, G4A, LR66, L626, LR626, GP77
AG5 Button Batteries: 393, 309, 193, LR754, LR48, D309, D393
AG6 Button Batteries: 370, 371, LR69, LR920, LR921, D370, D371
AG7 Button Batteries: 395, 399, LR926, LR927, LR57, D395, D399
AG8 Button Batteries: 381, 391, L1120, LR1120, L1121, LR1121, LR55, D381, D391
AG9 Button Batteries: 394, LR45, LR936, D394, GP394
AG10 Button Batteries: 389, 390, 189, L1130, LR1130, L1131, LR1131, LR54, D389, D390
AG11 Button Batteries: 361, 362, LR721, LR58, D361, D362
AG12 Button Batteries: 301, 386, L1142, LR1142, LR43, D301, D386
AG13 Button Batteries: 357, LR44, L1154, A76, PX76A, 303, D303, D357
This was very useful as I do not normally look at quartz watches, and my knowledge here is poor  thankyou very much
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
