Help Identifing Age of a Waterbury Mantel Clock
FrankCarpenter
Hello
I have tried to find information regarding the clock I recently received but have found nothing but a couple of images.  My clock is a wood case with faux marbling effect in brown tones.  There is a label on the back of the clock stating SAREPTA Waterbury Clock Company. Also on the label are three address one for NY, one for Chicago and one for Glasgow Scotland.  The number 4283 is stamped on the back of the clock case.  The entire back of the clock comes off to reveal the clock works.  The actual works are small in size.  The clock strikes on the hour and half hour.  There are no identifying markings on the clock dial.  The time regulator is located in the number 12 on the dial, however, the pendulum also has an rolling thread in the middle of it. Not sure the pendulum is original.   Any help dating my clock would be great.   Also the brass on the face and the feet is very tarnished. Does it hurt the value cleaning the brass?
Thank you.
Your clock is dated around 1895 because of the stamp on the back plate and not a label in side of the case. When it comes to polishing, myself I think it will look odd, you will be removing years of its life away. People like the patina of antiques they don't expect to see them looking like new. Unless you decide to completely restore the whole thing I would leave it alone. I also would say that pendulum is correct.
Here is the link where I obtained the date see if you agree.
  https://botspro.com/labelstrademarks.php?lm=Waterbury
Hi  There is plenty of information to be had on the waterbury/ansonia and jerome web sites. They are all linked.
Like Old Hippy says don't go bulling up the clock like new as it will spoil the clock, It picked up all the bruises and patina in life and to remove it all is an injustice to the clock as well to quote Old Hippy "it will look odd". So clean it polish it with care, Its a nick old clock and looked after will run another 100 years no problem.
When I try to go to the website in that link Firefox prevents it and I get this warning screen....
5 minutes ago, oldhippy said:
I had the same using Chrome but it is OK to use. I wouldn't post a link if it was dodgy.
Ok, was looking for the Ansonia link. I have this Ansonia cast iron clock. I got it about 55 years ago. The case was very rusty and as an apprentice in a scientific instrument manufacturers at the time I had access to stove enamelling, so stripped the case and re-finished it.....zQczflR.jpg
14 minutes ago, oldhippy said:
Looks good.
Bearing in mind that the re-enamelling was done about 55 years ago I think that anyone looking at it would be hard pressed to tell that it wasn't the original finish...;). Any idea of the exact age? My thoughts were that it was around 1900.......
1 hour ago, oldhippy said:
You will need to look at the label for the date. Here is another link for you and its safe.:D
http://www.antiqueansoniaclocks.com/ansonia-clock-labels.php
Thanks, very interesting, but I have no recollection of ever seeing a paper label with the clock.:(
Some close up pics which might throw some light on it.....
Movement.....
And dial..
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
