I'm rebuilding the keyless works on a 7750 and installing a replacement stem which I got from cousins and is specifically for this movement.
The stem sits in the movement fine and engages each position, but it won't engage the winding pinion in the first position.
Could it be that the winding pinion is worn and the stem can't grab it?
Thank you
Thank you
Ignore this, the yoke wasn't seated correctly
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
