In the end i realised my press was to cheap and nasty to line up the glass to the case accurately. I'd wanted to do it all myself but couldn't afford a better press for probably a one off and i didn't want to risk cracking another glass so i took it to a local watch repair shop and they fitted the new glass for £6. Excellent service and very helpful.
SO after a very long ordeal its finally back together and on my wrist working!! hurray!.I'm so happy. thanks to everyone who's helped and contributed.
Its been hard and stressful at times but i've also enjoyed it and have a real feeling of accomplishment. Think i might see if i can find a cheap movement to work on now and try and learn an bit more.
Thanks again.
Probably a wise decision Marlon. Your watch looks magnificent, and even better for being a driver! :)
  • 4 weeks later...
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
