My Dad recently passed and I received this watch through the dispersion of possessions. I would like to have it refurbished as I have no skill or tools to do so.
I can’t imagine that it is a very expensive watch but can I trust to just any watch shop to tidy it up or should I be looking for a ...Cortebert specialist?
That’s a good quality Swiss brand who actually were contracted to male watches for the British Military during WW2, so that gives you an idea of quality.
Any respected watchmakers should be fine to work on it.
Agree with Rodabod. I love Cortéberts and working on one now (pictured). Agree that any proficient watchmaker should be able to service your Dad’s watch, which I’m sure you’ll cherish wearing.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
