Much nicer photo! No I wouldn't be able to tell its a printed dial. No of course there is nothing wrong with exploring new ways of doing things--It is a question of aesthetic sensibility, which is a highly subjective discernment. I would hope we have the freeedom to disagree, just as we have the freedom to post on projects of our choosing? Of course, the important thing is to not become disagreeable.
Regards,
JC
I agree! :)
Although I think calling someone's work an "Abomination!!" borders on that. :) :)
By the way, the decal paper produced much lower quality results than the photo paper. For one thing, the surface of the decal paper is not as uniformly absorbent as the photo paper, resulting in some ink pooling and some dry spots. To get around that, I applied two layers of decal, since it was unlikely the dry spots would would coincide. Unfortunately, the slightest misalignment (even 1/1000th of an inch) then results in fuzzy edges.
I may attempt another "decal watch" with a light background, where hopefully I'll need only one layer of decal, and I also have another "photo paper watch" planned. Better cover your eyes! :)
Ok fine. I retract "abomination." I shall reserve my harsher descriptives for dials with misspellings, number or hour markers handwritten in pencil, pen, sharpie, or quill, and the use of neon colors of any shade, hue or intensity. Cool?
J
Edited by noirrac1j
J
Or the Apple Watch!
Thanks for the correction Mark. Yes decal paper then.....When I first moved to Brooklyn, I saw a guy painting his car with a gallon of house paint and a PAINTBRUSH. Afterward I saw that car parked on the street, and would often look at it closely: I could see the actual brush strokes--This watch reminds me of that car.
J
Show us one you made please?
Hello,
Thanks for the request, but I do not "make" dials. I have several posts with overhauls, rust, hairspring replacements and other issues, but I do  not produce home-made dials.
J
svorkoetter:
Fantastic work taking an "ordinary" watch and making it a really nice timepiece, that you also can use everyday. I like the innovative steps in the making, good job man..! :woohoo-jumping-smiley-emoticon:
And don't "listen" to anything "noirrac1j" writes. All of the sites/forums on the web has these people on them. Just ignore them and live with it... :sleep:
Thanks omega4sure. From your user ID, I can guess that you're an Omega lover. :-)
Joe: There's a big difference between what omega4sure is suggesting, and how you've taken it. You're entitled to your opinion, you're entitled to express it, and we're entitled to disagree with and/or ignore it.
Can you tell me what that big difference is? I'd like to hear your perspective on how I am taking it as you say; especially since you have no way of knowing that. On second thought--Don't tell me.
J
Your previous comment clearly implies that you think that we think that opinions such as yours should be silenced.
We don't want to silence you. But we can choose to ignore you if we want to.
This topic is now closed to further replies.
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
