Hi all,
Is it necessary to use a recommended Omega tool (as written on the case back), such as "tool 105" or "tool 107" to remove an original Omega crystal and gain access to the movement? Or, can I simply use my Bergeon crystal lift? I have used the Bergeon on other front loading watches (non-Omega) in which the watch's case back recommend the use of a specific tool without any problems. Of course, those crystals were easily replaced (at about $4) should there be an issue. With this Omega watch I'm referencing, the crystal has the Omega logo in its center so I assume it is the original crystal.
Thanks!
the easiest way to get an answer to the question is try it what's the harm that could happen?
sometimes googling is interesting like next link looks like they doing exactly what you wish to do? Basically Omega has a nice tool to take the crystal off without scratching it up unfortunately we don't all have those nice tools.
http://old-omegas.com/tool107.html
if the crystal has the omega symbol inside that tells you it's a original omega crystal.
no have to tell us where you do your shopping and you can get GNU one regional crystals at that price as seems really cheap? In case it's a replacement crystal we've discussed these before and vague memory isn't some people think it may not work. It may depend a course on who made the replacement crystal. That also pay attention to the inside metal ring Omega a lot of times has a slightly different shape than the generic one. It becomes more of a problem if the crystal is used to hold the movement in the watch. As opposed to normal crystal with the metal ring which just is a crystal.
Thanks for the prompt reply. The $4 price refers to generic GS or Stella plastic crystal for a non-Omega watch, more like the crystal one would put on a vintage Hamilton or Bulova.
Wow, that's a cool method, worth trying just for the fun of it. Then to reinstall probably best to use a crystal press. I've not used one yet, just the Bergeon, but I think it's time to invest in one anyway.
Thanks so much.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
