the bracelet is held onto the lug by a pin that runs thru.  The pin appears to be friction fit to the decorative ends.  How do i attempt to remove this type of pin??  The bracelet is broken and i need to replace it.20200907_121432.thumb.jpg.a89951dc04e9056265d54ca6224752cd.jpg
You have the pull out the ends, that as you said are friction fitted.
Good look findind a replacement bracelet, if no better choice a leather strap can be cut and fitted.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
