Hi, just looking for some advice regarding the reversing wheels. I am new to this hobby and have not come across them up to now. Just looking for advice on cleaning and lubrication. Will lighter fluid and ultrasonic be ok for cleaning? I am guessing that they are all metal construction. What about lubrication, would it just be the pivots that require lube? I have 9010, 9415 and D5 available to use. While I'm here is there anything else I need to take extra care with? Everything looks pretty familiar, just smaller than a man's watch. What lube would be best to use on the winding rotor post?Steve.
Wash movement parts with benzine (petroleum ether), U/S or not won't make any difference. Lighter fuel is not an horolological product, is not mentioned in any book or by any manufacturer, is formulated to burn clean and smell good, not to clean, it has been used a lot just because in the past nothing better was cheaply available as now.
Then you can lubricate by dipping  in the same product + 5% 9010. Dry preferably with warm air.
Thanks for the help. From my research I see that benzine is naptha and lighter fuel contains naptha. Any other opinions on that are welcome.
LIghter fluid is ok but check that yours is the good stuff. Put a few drops on a mirror and see if it evaporates cleanly. There will be a bit of a mark on the mirror but if there is whitish film left behind then its low quality stuff. I use Zippo fluid but in Malaysia there are a lot of fakes so I get it from a friend who is a Zippo agent.
If you have an ultrasonic cleaner then by all means use it.
Oiling as per JDM mentioned above.
Anilv
Naphta based just like motor petrol is, but we don't use motor petrol either, because of its additives and unknown microscopical purity. But petroleoum ether is not made for burning, mainly is used as fats solvent for testing laboratories and other industries where purity has to be guaranteed.
This I have explained very many times, and has been discussed in so many topics, but no matter that there is always some that doesn't want to move from the old habits, read a chemical label (which is notably absent on lighter fuel, at least in my country), or do a per liter cost comparison.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
