Hey guys
I need watch hands any kind or sort to fit a watch the hole size (and yes i have checked it is 1.6, 0.8 and the seconds 0.2.Tried cousins and they omnly seem to do them up to 1.5 for hour hands.
So were would i look now for a set of hands for a watch which the hour hand hole needs to be 1.6?
cheers
gary
My go to stateside is esslinger.  They also only have 1.5 on the  hour hand. A little  judicious  metal work perhaps? It will  be covered   by the minute hand.small blemishes would escape  notice.
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
