Hello,
I'm looking for a barrel complete for a Seiko 7009A I've found the part number, I've found some available online but I've found a cheaper one for the 7S26A. Their parts number don't match but are awfully similar.
7009A : 201.024
7S26A : 0201.024
Would one be compatible in the other ? I've read that the 7s26 and 7009 are quite similar.
My barrel and arbor are fine but it's cheaper and easier to buy a balance complete then only the mainspring unless there are generic mainsprings available.
Thank you all for your help.
7009A : 201.024
7S26A : 0201.024
That is the same P/N, only written differently.
Only the 7S26A and B would be the same. 7S26C is different.
There care but are relatively expensive and may not perform as the original.
You beautiful beautiful man ! Thank you for the detailed response.
I've found 2 used for 5€ which beats the NOS for 20€ since this is a watch I'm "working on" for practice and learning.
I'll use one on the watch for reassembly and I'll use the other to train on hand-fitting the mainspring back in the barrel since that how I absolutely murdered my original mainspring....:startle:
Thanks again, much appreciated
    • Like these? https://www.watch-tools.de/metal-straps/springbars/assortment-360-strong-spring-bars-beco-inox-o-1-8mm.php
    • I've seen them on several swiss-made movements as well. Last one was a Tissot if I remember correctly.
    • This thread might be interesting for you:
    • I've never seen them, then again, I haven't got a ton of experience, but "common"? Really? In what context have you seen them? I'm not questioning you. I am sincerely curious why I've missed it. An alternative to Fixodrop is to apply less oil (no more than 50 % of the circle area). The only downside would be that it would shorten the service interval. More oil will prolong the service interval, but if the movement is subjected to trauma, there's a risk it will be displaced. Fixodrop makes it more stable. Unfortunately, Fixodrop is seriously expensive.
