I thought of making a silicone strap for my wife sister fashion watch, which is special having 28mm lugs and being super short for a butterfly clasp and ladie's wrist. The maker is one of these Italians brands, leaving aside the look there is nothing to argue with the full SS case and Swiss-Asian chrono module, but they used the crappies ever plastic which fell to bits being left alone in the box few years.
The project is a made a bit easier because the two parts of the strap can be made identical.
I have seen that printing flexible materials is totally with a good choice of filaments
But I'm not sure that will work good for this need:
  • I understad is not not be possible to have any groove on the inner side which would have to be completely flat and with sharp edges to edges.
  • I don't think the springbar holes can be had directly, and precisely drilling soft materials can surprisingly difficult
  • I am not sure about the finishing from a consumer level printer would be adequate
  • A specialized printer is recommended, although from the video decent results can be had with a standard one.
So i thought of printing moulds, and there is at least one company which makes a two component silicone exactly for that.
  Still:
  • I don't know if printer and filaments good for moulds are special
  • Same worry as in direct printing about the finishing
  • Should be able to easily get the holes fitting a pin in place before joining the two moulds, which could also be identical.
Now, leaving aside that the cost of making this can easily be 10 times the price of a new watch, and the project level is probably too high for a total beginner, I am intrigued by the possibility of doing something at home that otherwise is not available at all, and wanted to hear some opinions here.
you might want to look at SLA printers. The number of resins has expanded quite a bit. plus the cost the predators has dropped considerably. I just did a quick search for flexible resins and the two links came up below.
then the second site that's a pain  to navigate somewhere in there I seen a reference to mold making. Although it was for injection molding harder plastics but it's still work for other stuff.
https://www.matterhackers.com/store/c/flexible-3d-printer-resins
https://dental.formlabs.com/store/flexible-resin/
Flexible materials are trickier to print -- or at least print decently -- than regular plastics in an FDM style printer. Resin printers might give you a better result, but you also have to factor in the chemicals for those printers.
I've printed a few things in flexible plastic and they look okay for utilitarian items, but for a watch strap? I don't know if it would be "good enough" to wear.
