Rotary Movement Help ?
RedJim
Hi All, Just after a bit of advice on a new find this week. Its a Rotary 1971 from the hallmarks on the gold case. Been trying to identify the movement on Ranft and trying to find a similar example but I'm struggling. Its a non runner at the moment so I'll need to strip it down so it would be useful to know what the movement is and if there is any reference material i can use. I've attached some pics if anyone can help or point me in the righat direction. Many Thanks.
52 minutes ago, WatchMaker said:
I can tell from the distinctive auto-mind mechanism that this is an A.Schild (AS) movement.
Probably something from this family: http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&AS_1983
Look under the balance wheel more closely and you should see an AS symbol. Can you also see a number?
Where would I get replacement screws for the movement, there are three I spotted highlighted in the attached pic, Ratchet wheel and  two case screws. Noticed Cousins have a selection, do you think they would do the job? Or should I be ordering specific screws etc..
I think I've located the missing Ratchet Wheel Screw in the movement stopping it working. Thanks again.
On 9/19/2020 at 10:08 PM, RedJim said:
Thanks, I need to look closer in future, thanks for your help.
Just to update the group, I retrieved the ratchet wheel screw and got it ticking. I can set the time but the winder stem is very stiff and I cant set the date which I belive is done by pulling the crown half out. I'll have to do a bit more work and remove and clean the stem etc. but thanks for the help so far.
    • Oh and the dc motors are an eye-watering £3.29 for 10. So this is the cheapest adjustable speed spindle for practising small turning, no excuse for not having a lathe now people 🙂
    • The site appears to be on the glitch in general.
    • Someone just made me aware that no images are showing in my post ( ). Could someone with the proper permissions check this? I believe the images are ones I uploaded to the site, but they could also be ones I shared from my OneDrive, which had an issue some time ago.
    • I would have jumped all over that set if it had come across my Ebay search results !  Very nice , well taken care of. I probably buy 10+ staking sets a month for my restoration hobby and think you found a very nice set, at a great price that should last you a lifetime.
    • Here's another old tool that doesn't get used much, but has saved me many hours and headaches when it has been.   This is a depthing tool, but quite special. The depth can be set (or measured) very precisely with the micrometer to the right, with a direct reading of the actual center distance between the wheel and pinion. It originally came with a set of the little plates in the slots to the right that take the pivots (first pic), most of mine are missing but they can be made when needed. The section that takes the right hand wheel can be adjusted in height. And it can be set on a profile projector if needed to check things. This one is marked Tripet, but most I have seen are marked Hauser. All of them were made by a small company in La Chaux de Fonds (can't think of the name now).
