I've been restoring a pocket watch that I found as a barn find. The dial bears the Berna brand and the movement has an M written on it and the number 179. Other indications of identity are lacking. While reassembling I ran into the problem of how the spring should be placed that presses on the pin that locks the mainspring barrel. (or, correctly, the wheel above the barrel, that is connected with the barrel through the square end of the arbor). I think the previous restorer did not correctly place back the parts here.
Can I ask you if you can identify this movement and/or indicate how this should be correctly put in place? Let me know if I can make additional pictures. Thanks!
I gather that ratchet wheel( the big wheel) turns clockwise to wind, in which case picture 3 shows the click spring's correct setting.
 Winding wheel( smaller of the two large wheels) should turn anticlock as you go to wind through the crown, therefor ratchet wheel turns clockwise to wind.
Show the click's  bottom-side upclose, click pin might be broke.
From the bottom photo, the click pin is still there. The position in photo 1 and 2 is correct. You just have to get the tail of the spring into the box. You can use a pegwood stick to hold it down in case it decides to fly away or just use your finger.
Sorry, position of spring in photo 3 is correct. But position of click in 1 and 2 is correct. You have to pull back the spring to engage the click pin on the underside.
Thanks for the replies! I've tried applying the tips and it nearly works; I think the spring is just a little bit too short to keep the click thing in its right position.
In the meantime, I've finished it as-is, see the result here:
Things left to do: polish (or replace) the glass, check the spring for the click element, get case screw (one missing), and likely get a new hairspring (when 'wound', the balance doesn't rotate as much as it should..).
    • This is indeed a unique site and members including myself genuinely care about it.  All we want is the site to continue.
    • Hello Mark,  thank you for the ad removal , like JohnR725 , I appreciate any revenue from such would be helpful.  This is the one forum which encourages conversation and social interaction and in that sense it is unique  All the others I frequent can be a little intimidating and answers some what terse some quite rude. I think on here we try to do justice to your site in keeping with your principals. In my opinion it is like no other. The contributors  behave and act like gentlemen and ladies. And long may it continue to be so.
    • The high voltage will take a toll on the battery but if used occasionally such a the proposed bridle welding I guess if it works it’s worth the price of a battery.
