Some of you may have noticed last week, I was struggling with a major update for this forum software.
I was getting a lot of errors in the back-end and it was making it very difficult to manage.
I rarely do this, but I opened up a support ticket with the developers (Invision) and at first they put the blame on third party plugins, something I knew was complete BS, but I went through the process and eventually we got bumped up to 1st level support after quite a bit of whinging from yours truly.
1st level support immediately saw that it was a bug on their end and we had to wait until today, a minor update has been released by them and I am happy to say that the issue is resolved.
What does this mean for the forum - well not a lot but the backend is running more smoothly with no errors.
EMOJIS
What this does change though is the way this site handles emojis - you know - ? ? etc etc. and mobile users (me included) will particularly appreciate this. Before, this website could not handle mobile standard emojis as keyed into the keyboard of a phone or tablet (or even the emojis in, say, a macbook touch bar). These style emojis are now pretty much standard, but the forum would throw up an error if you tried to post with a standard emoji. I'm happy to say that the database this forum runs on has now been updated to support standard emojis and the old emoticons have now been disabled in their favour. Going forward this will reduce errors when you are posting on mobile devices and any keyboard that is emoji enabled. So - old 'Emoticons' are gone - Emojis have replaced them.
And another first world problem is sorted ???
  • Thanks 4
Thank you Mark!
Your efforts and dedication to this forum do not go unnoticed.
If you were a few thousand miles closer, I’d buy you a beer.
Which perfectly describes the standard IT support process, as you, I and everybody else in IT knows.
Yes sir, I refrained from  whining about that just because I could live without emoticons.
Thanks!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
