double fusee bracket clock
rajeshvyas
oldhippy, thanks. yesterday i tried with 20" same brass (0.8mm thick) hand but it did not worked it stopped between 7-9 position. then i reduced the length to 18" + reduced the thickness to 0.6mm and it worked-and still it is working keeping perfect time. can u suggest me the best suitable (especially for such large size clock) some more light metal for making hands? i am also planning to make rib to give more strength.
Aluminum would be my choice if it needed to be longer. You can go quite thin and place a center crease in the hand to stiffen it along it's length (or curve it)
You can always "skeletonize" whatever hand you choose too, and I think the counterweight idea was already mentioned, for the opposite side of the pinion.
Poising the hand on it's pinion should eliminate the "positional error" of the load on the movement, so it's not faster after noon as compared to before noon. Something crude would do- it wouldn't need to be "balance wheel" perfect.
I have often pondered this with wristwatches (poising the hands), but there isn't much point, due to the infinite positions the watch is kept in at any time. But a clock on the wall is always "noon up" so it's a bit easier to manage I think.
The movement is all ready fitted with the counter weight. Aluminum will be to flimsy and skeletonized hand will not be in keeping with this movement. I'm pretty sure the movement is the type that would be over hanging a shop or in a large hall type room.
I think I’ve only just understood this “counterweight” query. So, there is already a counterweight attached to the motion works..... if you disengage the going train then you’ll be able to judge what length of hand counteracts the built-in weight.
rodabod, yes the counter weight is already fitted to the movement. now to judge the length of minute hand if i disengaged the counterweight then how i will know the load carrying capacity of the movement? i have already tried with 18" brass 0.6mm thick hand which runs perfectly OK. today i am increasing the length to 20" and again try. if 20" works well i guess i must stop more experiment and finalize the length!
One thing to watch out for is the excessive positive drive that you could get if the hand was significantly heavy and falling (so, say at the 15 minute mark).
Recoil escapements are good at dealing with varying drive/amplitude, but it doesn’t necessarily make it a good idea to design it to vary significantly.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
