I have a Casio MTD-1079. I  installed the backlight battery. The backlight works until I tighten down the bezel. I'm not tightening the bezel much either for the light not to work.
Any advice would be appreciated. Thank you.
Perhaps a contact is over bending or something is warping when you tighten it down. Is the battery an exact replacement? A little taller or shorter will cause problems too.
And you should not post the same question in multiple sections!!
