Have you taken the BHI Technician DLC? Tell me your experience!
By watchweasol · Posted
Hi. Replacing the movement is the easiest option, if that’s the way you go then by all means utilise the old one for practice. You can get an assortment of crowns via Amz or Cousins which ever you find the most convenient -
I would suggest for the drill use a size 58=1.07mm then turn the pivot to the size you need after fitting the part that way you can be certain that the pivot is concentric with the rest of the arbor. Dell
By stonestonestone · Posted
Thanks for the help. I don't see anywhere where it would connect to the case back, although I do see perhaps a spot on the oscillator/vibrator that based on the bend and length of the wire, I suspect it may go. The same connected wire goes up to one side of the body of the oscillator/vibrator, so perhaps this one is also supposed to be connected to it. Let me know what you think. -
@andygsi initial plan was to work with existing movement as a learning session. Since the common thought was replacing unit i will do that. I think i will keep old movement and learn with it and buy a new one for the watch
