Oh I did enjoy watching that CB, what an incredible piece of horology! The centrifugal regulator for the chimes is so good it should have been made visible through the dial. :)
I agree Geo and the craftsmanship is astounding but like many top quality watches the finish quality & movement is hidden under its case.
BUT who would wear such a watch ?
Some very very very very rich person, and only very very very very occasionally.
This video has been mentioned before, if I remember correctly, because I've seen it before.
And, yes, I have two these.
In my dreams...
Will
:D
Edited by WillFly
It's telling to me that the computer does the rough work, but all the fine details and the finishing touches are manual.... Every time I see one of those, my jaw drops... And I have yet to see one for real.
I don't have money enough just for a hinge of the box it came in... :( and so complicated but it is not prepared for "summer time" auto adjust. :)
Our younger son was 7 years with Patek in Geneva, among other things setting up a quality control facility.  During one lunchtime in their canteen I was introduced to one of their bods who did some of the most delicate assembly work. He was part time - a watchmaker early in the morning and a farmer who looked after his cows later in the day. There is a lesson to be learned here!
Incredible!
If anyone finds a bit of straw in their Patek they'll know who's responsible! :)
Milk -> lifestyle -> early mornings ->steady hands, beware you malt lovers.
Incidentally the Patek film was run continuously in the window of a licensed Patek watchmaker's shop in Aachen last summer. It attracted quite a crowd; great publicity but not many takers.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
