Purchased an automatic mainspring instead of a manual from Cousins. A bit pee’ed off at my mistake, so tried the repair. Any tips or advice from the experts will be gladly received on how to improve the process (if there will be a next time) The photos are pretty self explanatory to the process I tried. I used superglue to hold the 2 pieces in place before drilling and riveting, then will acetone it all away at the end. (For some reason the last photo should be the first photo)
  • Like 5
  • Sad 1
The riveting looks good. What steel did you use? Did you turn the rivets with a head, or rivet both ends? How did you make the holes and the chamfers? How did you remove the automatic bridle? I like the idea with the superglue. Did you chamfer the end of the hook, so that it doesn't slip off the step in the barrel wall? Lots of questions I know, but the devil is in the details!
Hi Klassiker,
I used mild steel as I thought it would give a bit more when hit. I turned the rivets with a chamfered head, and ended up hitting both sides with the staking punch as it just felt more secure to do it like that. I snipped off the automatic bridle and used a bit of it for the hook piece. I did not chamfer the end of the hook - fortunately it is not in the barrel yet, so I will do that - thanks, I knew I woiuld learn something on this forum!! And the holes were drilled on a drill press and then chamfered with a bigger sized drill.
Hi Hector, I did think about soldering. It would be a lot quicker. I did not try that basically because I have never seen a main spring soldered as a repair. What do you think? I could heat protect the spring to the end and try a little silver solder, or I have some flux for soft solder that works with stainless steel so I might get a half decent joint with that?
Thanks both for your replies.
I have seen a method in an old book where the end of the spring is annealed then folded over and hammered flat.
I tried it on a broken spring that I had but it snapped everytime. Maybe my spring was already fatigued or the steel in the old days was different.
Think it is a good work put into that repair.
Just as @HectorLooisaid there is an alternative method to do it, think it is Donald de Carles great books he thinks of, they are well worth investing in.
Here is his riveting method.
And the forming method.
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
