I'm about to embark on swapping out a date wheel on a ETA/Valjoux 7750. (Black instead of white to match the dial)
Any tips or pitfalls I should be wary of and take extra care with?
Also, a separate project will be determining why the hour subdial doesn't stop running. It will reset when the pusher is pressed, but then it doesn't stop and just continues running. Any ideas what could be wrong there?
Thank you!
Don't have any specific experience with an ETA 7750 movement but I think this applies to a lot of movement with date complications - be careful when removing the date cover plates because sometimes the spring is loose and it will want to fly to a place of no return. Same goes for reassembly.
Good luck!
13 hours ago, Klassiker said:
Did some searching and found this. Is your hour counter creeping, or running at the right rate?
It's running at the correct rate and resets correctly but then doesn't stop. As though it didn't have a brake or something?
The chrono hands were a total disaster. There were on so tight I couldn't budget then. Created three massive problems:
1. I slightly bent the running seconds pinion/hand holder
2. Worse, I snapped the pinion for the minute counting wheel ? It came right out inside the minute hand tube!
I found on eBay a seller for replacement minute counter wheel for $30. Is that a reasonable price? https://www.ebay.com/itm/New-Sealed-ETA-Valjoux-7750-Watch-Parts-Balance-Fork-Wheels-Pinions-etc/133380243986?hash=item1f0e150212:g:z4AAAOSwn8Jeimn1&var=432805034001
Any ideas how I remove the piece of the pinion that's stuck inside the minute hand tube?!
The hour-counting wheel should be kept in place by the hour counter lock, but if the hour hammerspring is out off place the hour counter lock can't be locked in place by the hour hammer.
But I have no idea how to remove the pinion from the hand tube ?
I have been working on a Chinese clone with the hour counter problem. I know that you need to take the plate that covers the mechanism of the counter off very slowly without disturbing the parts . So you can tell why it's not working. Most of the time the spring has flip over or under one of the levers. I've had to put a small bend in the spring so it's better trapped between the plates. This is the worst designed part of the 7750 movement, if you ask me. I've had to take mine apart 3 times now, to fix this problem. By the way my clone is keeping time to within 2 sec. a day.
  • 3 months later...
You could try pushing the broken pinion  out from the front of the hand, be sure to keep the hand flat though. A small pin may fit the hole on the front.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
