I recently purchased a seiko 7T62 and the bezel is off the watch I sourced. Correct bezel gasket 86583460 but I have crushed it while trying to fit, does anyone know about fitting these bezels i have got replacement gasket but worried about ruining another one.
1 Do you fit gasket to  the tachymeter bezel then try press fit ?
or
2 Do gasket put gasket in the case then press fit the bezel into it ?
Any help or advice appreciated. Anyone ?
Edited by Nomad1001
uloaded a picture
First fit he gaskets to the part that has a shoulder to seat and stop it. Check if there a chamfer to help the other part fit. You need a good crystal press and much attention.
Thank you JDM for the reply.
just to make clear i put gasket into watch shoulder then press the bezel into that i have added another picture just to make 100% the gasket has a shamfer so i would assumei that would point up
As jdm remarked fit the gasket into the case (chamfer side up) make sure it is seated, What I do is moisten the edge of the glass and fit it square on the gasket in the case and apply the press slowly checking the fit and there is no possibility of crimping.       all the best.
Hi Watchweasol thanks for the assistance the glass is bezel mounted so already installed as  in the picture above the problem is that the tachymeter ring then sits in a gasket in the case so metal to metal with gasket in between but from both your remarks ill fit gasket into case then fit metal bezel \ tachmeter ring.
thank you for replying and your assistance
Wow Thank you the guide is great the case and bevel look more like A4 than B0 i will look when home.
if it is then the gasket fits on bezel first as below .
