400 day clock,
chriseames168
Hi hope someone can advise me, I have a 400 day clock and looking for a new spring wire unit,I have the 400 day clock repair guide and think something in the book is got a error in finding the correct strength wire unit and length,the plate number for my clock is a s Haller plate 1521 miniature clock,spring 0022 056mm the unit for this clock is a 43 43a for a better fork type but when you make the unit for this plate the size of unit in much longer spring length,I find the correct size length for my clock and it is asking for plate number 1522 what is not the same model but correct length size of spring on this model is 0018 046mm unit 43/43a/44/44a can someone advise for correct spring strength wire I should purchase,thank you,
Hi
Do I understand you correctly, you are making up the suspension spring for this clock, using the information in the 400 day repair guide book by Twilnger(spelt wrong I suspect).
For this book to be correct, you must use Horolovar springs, no other make will work correctly.  This is to do with the way Horolovar springs are made, other makes are made differently.
Horolovar springs come in only 2 lengths, the lengths given assume the support columns are correctly assembled, the spring will almost certainly need cutting down.
Once the clock is running, set the pendulum to mid adjustment, then note how fast or slow it is running, if this can be corrected by adjustment, then good.
If not, then changing the spring thickness alters the beat timing for the clock.
Bod.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
