You can post now and register later.
If you have an account, sign in now to post with your account.
It's either bent or hung up on something or both. The hexane won't hurt it, and hanging from a balance tack indefinitely won't hurt it.
If the spring is glued to the stud there's a chance that the glue was softened and the outer coil stuck to the stud. Haven't seen that happen, but I suppose it could. Don't know if hexane affects the glue used either.
Hello all.
some help required here from the community please.
I serviced this movement, which was running reasonably well, but the balance spring which was running healthily before I started, after cleaning in hexane for 30 secs, is all bunched up at the stud.
I did store the balalance on a tack thereafter for a day.
could the spring be strained under gravity? I demagnetised of course, and the balance is squeaky clean.
some help would be much appreciated. Thanks, Tony G
