Hi
I recently serviced a chronograph from late 40s/early 50s as it was dry for decades and balance stopped occasionally. But after service, it looses at least 10 min per day. I recognized that the watch stopped when tilted and I solved the issue by polishing the pallet bridge screw.  One watchmaker says it can be a slightly worn staff or wing but the balance runs good by sight, another says that the spiral is too long and the staff is alright. What do you think it is? Let me know if different images required for inspection. All answers appreciated.
Edited by Khan
Are you achieving good amplitude? The video suggests you probably are.
Does it still significantly lose time if left dial-up like it is in your video?
Was the pallet screw fouling the balance previously? Are you absolutely sure that this issue is now corrected?
Have you check the balance end-shake / side-shake?
Yes, amplitude above 270. It keeps the time like 20 percent better when dial up. I also measures the timing while removing pallet bridge screw but still the same. How do I check end and side shake? I know that the balance wing is a bit shaky when checking the vertical movement by tweezer holding edge of balance wing. And when shaking the watch, there is a rattling sound coming from the balance and can stop occasionally by that.
It's a non-antishock jewel setting, so be careful, but you can gently grab the edge of the balance wheel and lift it up and down. Try to see if you can see excessive side shake. If you are not confident doing this then lift the edge of the balance wheel with a fine oiler.
Yes, I grapped the Edge with tweezers and there is a Visual vertical movement of the wheel by maybe 0.2 mm and feels abnormal. But no horizontal shifting by feeling.
Edited by Khan
So, it's hard to describe in words, but basically it should be able to lift and drop by a small amount (end shake) but when you lift it, it should not tilt much at all (side shake). I'm not sure if there are any videos online demonstrating this.
It's a tricky question, because if you are adjusting the positions of the jewels then that assumes that they are currently incorrect. But it's more common to experience a worn or broken staff. It's worth repeating the end-shake test while observing the position of the roller and impulse jewel relative to the lever fork (while the balance is at rest) to see if the parts interface correctly.
As an experiment, you can reduce the end-shake very slightly by placing a thin dial washer behind the balance cock screw hole (on the outside edge of the movement) to tilt the balance cock down ever so slightly. You need to be careful when doing this in case you reduce the end-shake too far and damage the pivots.
0.2mm is way too much shake. 1/10 of that is good.
Your pivots appear ok. It looks to me like the hairspring is tilted down opposite the stud and is possibly touching the balance arms when running.
What lift angle are you using? Landeron is typically 42. If you have it at 52 you'll have a false high reading, and if the hairspring is touching the arms it would be normal for the amplitude to be low and have a losing rate.
Hi, Perhaps a typo there and 0.02mm was meant, .  I presume you are talking axial staff play, which I reffer to as end shake. How about side shake? I havn't seen a number given for it, I just go by the feel. putting the two end+side shake together, if pivot stays put ie; doesn't jump out of jewel hole as one side of balance rim is lifted, shakes will not stop the oscilator.
I avoid lifting balance wheel, however gentle, I fear it might knock the rim out of true.
TIA
Regards joe.
It's sometimes hard to judge where the hairspring is sitting as the weight of the stud moves the spring. Holding it vertically (or resting the edge of the wheel on rodico) may give you a better idea.
I'm still wondering about when you said that you had to polish the pallet bridge screw. Unless the screw has been swapped, this doesn't sound correct to me. In your most recent video, at the very beginning, the balance rim looks quite close to the balance cock. Are they ever able to come in contact?
With the watch running (and not running as well), I would check that the hairspring is always clearing the balance arms as NS suggests and that the rim is always clearing the pallet cock by observing the gaps highlighted in the photo attached.
Observe the roller table from the side view as you( gently) raise the balance wheel with a clean oiler or tooth pick, etc, the frèe play on the roller or anywhere else on the staff is your axial free play which we call end shake.
Side shake is the lateral frèe play on staff, so you ( gently) pull or push on the side of any part of the balance as you keep an eye on the staff in jewel hole, any free side play that you can notice is called  side shake and eats amplitude.
Did you remove the end stone plate on both side to clean and check jewel holes under high magnification? if the hole wears out you get excess side shake.
You can check balance pivots under high magnification for signs of wear or scratches and if thinned and pivot-endstone interface for wear.
Mere Excess end shake can cause positional variations in the range you are seeing.
I removed the hairspring and put it back together to ensure a gap between hairspring the balance arms. This still doesn't work and I believe there is too much end shake. There is a remarkable vertical movement when lifting the balance wheel while installed.
Positional variations will improve as you reduce that excessive end shake, I shim the cock to lower the jewel.
I presume all data you give is without the chrono load.
"Spiral too long"  is begining to sound correct.
I have noticed that there are two variants of the balance staff for the Landeron 39, the Shockproof and the Super Shock Resistant.
I don't know the difference between them, do you have the right one in the movement?
/Carl
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
